nitroman189
- Jul 19, 2008
- 1
I have a 1996 135 mercury that is oil injected the problem i am having is when i hit the gas to take off it boggs and dies but starts right back up and idels fine and in netural it will rev right up . if i put it in gear and go slow on the gas it will start to go and build rpms up to normal and when i stop and hit the gas it takes off no problem but if i stop and sit for a min and hit it ,it boggs out oh before i forget once i do have it running at a steady rpm you can see the rpms drop and go up about 400 rpms any ideas what could be the cause ?????????? I am new on here so any help would be great . thanks
