  #1
Old August 15th, 2008, 10:30 PM
mpf mpf is offline
Default Yamaha 1986 200ETLJ Oil Injection problem.
Pressure seems to build up in the engine mounted tank and pops out the oil level sensor. I have changed the oil level sensor and the problem still happens. On other posts I have read that this means the problem is the control module. Should I change that next or take it to a mechanic.
I have read that you can "ohm" that output from the control module to see if it is giving a bad command. How would I do that? Would I probe one of the leads to the remote tank?
When I turn the key to on, I can hear the remote tank whirring, even when the engine mounted tank is full. Does this rule out a venting problem?
If I can be sure the problem is the control module, I would try to change it myself, unless someone thinks this problem is best referred to a technician.
But, I want to learn to service my motor so I understand it as much as possible. Also, if money wan't an issue I wouldn't be using a 1986 outboard (which runs great by the way).
Am I better off running premix at this point. If so, what changes do I need to make to the engine and what ratio do I run.
I like the idea of running premix because of fewer parts to break but wouldn't premix change the characteristics of the carburetion? Also, wouldn't the carburetors be more likely to gum up?
Thanks in advance for all advice.
  #2
Old August 16th, 2008, 09:41 AM
rodbolt rodbolt is offline
Default Re: Yamaha 1986 200ETLJ Oil Injection problem.
gotta run for some breakfast, ill try to answer some questions later,
dont buy anything just yet.
post the wire colors from the engine tank switch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha Oil Injection Problem B Money Yamaha & Suzuki Outboards 8 June 25th, 2007 10:02 PM
1986 Yamaha 150 oil injection 2manyboats Yamaha & Suzuki Outboards 4 June 30th, 2006 07:16 PM
1986 Yamaha 130 want to remove oil injection ??? fishon71 Yamaha & Suzuki Outboards 6 April 28th, 2005 06:52 PM
Yamaha oil injection problem fastkenny Yamaha & Suzuki Outboards 2 October 12th, 2004 06:22 AM
Yamaha Oil Injection Problem RangerJer Yamaha & Suzuki Outboards 28 September 3rd, 2004 03:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
