Re: '93 Johnson 40HP No Fire
Ok, while I am waiting on a service manual, I have the above engine that hasn't been run in about 15 months (father in-law). I have emptied the gas tank and put fresh fuel, drained the carbs, cleared all fuel lines, and no fire. The plugs look good, but when I pull the plug and lay it against the engine to ground, it does not fire. I am pretty sure it is grounded enough, but no fire. Where should I go with a multimeter?
Second, the primer solenoid is spurting fuel when the primer button is pushed. I pulled it off and all looks ok, so I have to assume it is the O-Ring. What the heck is the red plastic and schraeder valve for??
Any help would be appreciated . .
Thanks!
Mark
