Just got my boat out of the shop today to have new gimble bearings, shift cable, bellows, new water pump and housing, changed oil on outdrive, u joints - they said were fine. I get it home, put outdrive down, connected the water hose so I could test it, started it up, warmed it up, put it in forward, worked fine, then put in reverse and I heard some sort of clunking at idle. I could feel this in the fiberglass as I was sitting in the boat. What could this be? Just had the whole thing serviced, was running great before this. could it be bad alignment of the splines between the motor and outdrive? Almost sounds like something is loose in there, jerking and clunking back and forth,
Any comments would be appreciated.
