  #1
Old August 13th, 2008, 05:30 PM
Indyboater Indyboater is offline
Default Hard starting 4hp Mercury
I have a 2004 4 hp Mercury outboard on a small fishing boat that stays at the dock. When not in use, the motor is tilted up, so the lower unit is out of the water. The motor is difficult to start initially. Per the instructions, I choke it for two pulls. It will often start on the first or second pull, but then dies immediately. Per instructions, I push the choke in. It will then take anywhere from 6 to 15 pulls before it will start and continue to run. I have replaced the spark plug and set the slow and high speed carb adjustments as the owner's guide suggests. After running, it will restart easily. What should I check or replace?
  #2
Old August 13th, 2008, 09:13 PM
TOHATSU GURU's Avatar
TOHATSU GURU TOHATSU GURU is offline
Default Re: Hard starting 4hp Mercury
It sounds like a dirty carburetor so have it cleaned. Really cleaned, not sprayed with some fruity mechanic in a can carburetor cleaner....But, I'm intrigued by what you think you are adjusting. If you have a 2-stroke, there is an idle RPM adjustment and an air mixture screw adjustment. If you have a 4-stroke the only thing you can adjust is the idle RPM.
__________________
Elvin
My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
My Three Rules:
1) Look in your service manual first.
2) Have basic mechanical skill.
3) If you are confused, take your engine into a dealer.
  #3
Old August 14th, 2008, 12:49 AM
This is a two cycle engine. It has a slow speed carburetor adjustment screw and an idle speed adjustment screw. I mis-spoke mentioning high speed adjustment -that is fixed. I got my motors mixed up. Nonetheless, the starting difficulty has been since the motor was new, so I don't think it was shipped with a dirty carburetor. but I will clean it off-season.
  #4
Old August 14th, 2008, 05:59 PM
"It has a slow speed carburetor adjustment screw" No, that is an air mixture screw.
__________________
Elvin
My Three Rules:
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 Johnson 4HP hard starting Hank007 Johnson & Evinrude Outboards 4 August 15th, 2008 11:30 PM
Starting Mercury 4hp-4 stroke soh_2 Mercury & Mariner Outboards 1 August 12th, 2007 03:38 PM
Hard Starting Mercury 7.5 steam_mill Mercury & Mariner Outboards 12 August 5th, 2005 09:58 PM
Hard starting 90hp mercury ther2525 Mercury & Mariner Outboards 1 June 12th, 2003 06:00 PM
Hard Starting Problem/ Mercury O/B Fish Head Mercury & Mariner Outboards 4 August 12th, 2002 06:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
