model 1g5 025-3562
ward sea king 1.5 hp manufactured 48-50
Motor has sat for some 20+ years
After cleaning the gas tank putting grease in lower unit and a new spark plug a little gunk in the carb this motor started on the 9th pull.
Now here is my problem. It will start easily now after running always on the first pull/run fine on slow--but when lever is moved to fast the engine immediately shuts down?????
I put some sea foam in the gas mixxture and am wondering if I let it run is it possible for the carb to clean out enough to correct itself or will I need to take the carb apart (which I have never done)
Thanks for any suggestions!
Gary
Gary
