1987 Yamaha 115 not getting fuel
i have an 87 yamaha 115 etlh 2 stroke..idles great but has an obvious fuel starvation problem..when i give it throttle it'll go for a couple minutes then bog out. if the bulb is pumped while running it will run great and get to full throttle then the bulb goes flat and again bogs out. Spark tested good except questionable on two so i replaced the two coils.Compression is good,tested 130 on all cylinders.Timing was way out of whack, but good now. Has new spark plugs,primer bulb,and even put in new fuel pump as well as a new fuel line from the tank to the motor and also removed carbs and throughly cleaned them. After all this,it still has same old problem. The only thing i havent replaced is the fuel pick up. I should mention that when i bought the boat i discovered the bulb was deteriorated on the inside and had shot rubber sheds into everything but that should all be cleaned out now. The boat is an 88 starcraft 18ft deep v. Any help would be appreciated as my wife is about to ring my neck after spending 4,000 bucks on a boat that wont go fast.haha THANKS
