  #1
Old August 11th, 2008, 06:25 PM
brian91z28 brian91z28 is offline
Default Is it ok to run my 94' evinrude at low rpm's
I own a 1994 Lowe sea nymph with a 70hp evinrude. It has a new powerhead in 2001, and the previous owner did not know why. I want to troll with it on lake Michigan, but I am nervous about running at such low rpms, is this bad for the engine? I did make sure that it is not running lean, it runs great otherwise, again just nervous running on the big water.
Brian
  #2
Old August 11th, 2008, 06:36 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: Is it ok to run my 94' evinrude at low rpm's
No problem with that at all.
Things to note though. Be sure your plugs are correct, and are properly gapped. If doing heavy trolling, gap them an additional .005. I would decarb annually, along with adding a fuel additive such as Seafoam to my tanks. Also be sure your t stats are functioning as they should. This will prevent your engine from running cold.
Good luck.
__________________
Chris
  #3
Old August 11th, 2008, 06:55 PM
Thank you for the reply, I was originally going to use my electric trolling motor, but I now feel comfortable using the regular motor. This site is great!
Brian
  #4
Old August 11th, 2008, 07:05 PM
Jayboid Jayboid is offline
I use a 9.9 hp kicker motor. The great thing about that is that you can put it on as a permanent install and use it for an emergency engine as well as trolling. I wouldn't want to be out on Lake Michigan in a storm and a conked-out engine with only an electric trolling moter to get me home. Trolling with a kicker motor keeps the hours off you big motor and keeps your spark plugs clean.
  #5
Old August 12th, 2008, 12:32 AM
Randybeall's Avatar
Randybeall Randybeall is offline
One of the things we forget is that the prop needs to be correct for the engine even if we are running it slow. Because the engine is fully loaded when the prop is in the water it must be the correct pitch and size. The best way is WOT test. Engine should just reach maximum rpm at WOT and not over rev or be lugged down. This assures the engine is working correctly through out the range.
  #6
Old August 12th, 2008, 06:17 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i agree on the proper prop, your wide open rpms, should be between 5500-6000 rpms, then the motor works correctly at all speeds.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #7
Old August 12th, 2008, 01:28 PM
Prop is original, and it does run approx 5600-5800 rpms when WOT, I did take the other guys advice, and I found a 2.7hp cruise and carry cheap. Its only 12lbs, I think it will work great!
  #8
Old August 12th, 2008, 06:40 PM
Randybeall's Avatar
Cool, thanks for the update. Some people don't care to give the feedback and let everyone know they appreciate the opinions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1993 150 Evinrude RPM's To Low? scottpellegrin Prop Questions and Topics 8 July 27th, 2007 02:50 AM
'90 15hp evinrude has low RPM's at WOT Gregjg Johnson & Evinrude Outboards 8 July 11th, 2006 12:25 AM
1983 Evinrude V4 90 HP Low RPM's skeeter 1 Johnson & Evinrude Outboards 5 May 21st, 2006 01:10 PM
1989 Evinrude 150 won't run over 2800 RPM's SBaldeson Johnson & Evinrude Outboards 0 July 4th, 2005 02:33 PM
Evinrude Ficht 150 . . . WOT => low RPM's bigshrimpin Johnson & Evinrude Outboards 8 June 18th, 2005 08:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
