  #1
Old August 11th, 2008, 05:50 PM
kickstand0929 kickstand0929 is offline
Default moldy pontoon deck carpet
I have tried everything I know to try to get rid of the green mold on my pontoon deck carpet. The boat is a 2004 tracker with marine berber carpet and everytime it gets a little wet, it molds. I've tried hydrogen peroxide to kill the mold and pressure washing it all away and the day after I take it out, its back. I've tried changing the location of where I keep it and the same thing. Any ideas please???
  #2
Old August 11th, 2008, 05:51 PM
Default moldy pontoon deck carpet...please help
  #3
Old August 11th, 2008, 07:37 PM
ratracer ratracer is offline
Default Re: moldy pontoon deck carpet
Getting mold out of carpeting is tough. You have to make sure that you kill the spores and get the carpet dry as quickly as possible afterward.
You can try wetting the carpet with a solution of a cup of bleach per gallon of water and let it sit for at least 30 minutes in order to kill the spores then use a shop vac to pick up the excess water, then use a fan blowing over the carpet to help speed up the drying process. You do have to be quite careful and there is some risk that you'll bleach out some of the coloring in the carpet and/or discolor anything metal that the solution touches.
Or, you can try something similar using a commercial solution to kill the mold spores.
  #4
Old August 12th, 2008, 02:50 AM
SturgeonLake SturgeonLake is offline
Default Re: moldy pontoon deck carpet...please help
As far as cleaning goes, Bennington told me to use a scrub brush and a little soap.
As far as keeping it clean, try a squeegee. The problem is the water that's being retained by the plastic carpet (I assume its some form of plastic.) Pushing out the water will give nothing for the mold to grow in...until it rains...which is why my playpen cover covers the exposed external deck too.
If you've used chemicals, then what you are seeing isn't growing mould, but the mould you can't get rid of via whatever means you're using (e.g. power washing.) Remember, the carpet has many facets, front, back, sides, etc... so you really have to scrub to get it "clean." Chances are your chemical attempts have killed the mould (at the time of treatment) but that doesn't mean it looks clean because that mould was 360 around each fibre. More power spraying may work, especially if you get it from all sides...no easy task.
A brush, squeegeee, and then brush again, then hard hose spray worked for me.
__________________
Bennington 2275 RLiC w/ESP + Yamaha F150
  #5
Old August 27th, 2008, 12:16 AM
wobble1 wobble1 is offline
Hey dude I maybe a little late But if you havent cleaned her yet go to dollar store get a large bottle of greased lightning wet spray her and pressure wash let dry should kill most of mold bought mine 2 years ago carpet was super duper bad turned out very nice 1990 original carpet good luck had no discoloring at all
  #6
Old August 27th, 2008, 12:21 AM
Smile slip hinges
I am looking for a supplier who carries the small style slip hinges for gate on pontoon not the piano style about 2x2 aluminum need desperately any advice would be great thanks 1990 suncruiser 24 ft Have a good holiday everyone
  #7
Old August 27th, 2008, 12:33 AM
OldePharte's Avatar
OldePharte OldePharte is offline
Default Re: slip hinges
Quote:
Have you tried West Marine? They make some take aparts. Or ar yuo looking for those that rise as they open?
__________________
2009 Neptoon 25TT Sport Sun Lounger
150 Honda
I don't skinny dip . . . . I chunky dunk
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
seal plwood deck before carpet fishkiller Boat Restoration and Building 7 May 19th, 2008 02:26 AM
Bass Tracker Deck & Carpet devisetek Boat Restoration and Building 6 October 22nd, 2007 08:13 PM
cleaning pontoon carpet????? tnimmortal Boat Topics and Questions (not engine topics) 3 April 3rd, 2006 03:45 PM
Removing carpet from pontoon boat wood deck geezer1960 Boat Restoration and Building 2 March 14th, 2005 12:22 PM
Cleaning Pontoon Carpet rogerwa Boat Topics and Questions (not engine topics) 4 August 3rd, 2004 07:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
