I have a 1986 bayliner with an AQ131A/275. I bought it 2 years ago and the the compression was 175 to 180 on all 4 cylinders. This spring it wouldn't start and after trying many other things, a compression test showed 70 lbs on all 4 cylinders. I removed all of the accessories and can't find the timing mark on the valve cover. I have a Seloc Publications book, but the pictures appear to be from an older model (cam pully mark in the picture is a notch on the outside of the pulley, rather than a dot on the pulley like my boat). I am guessing from pictures I've found that I may be missings a guard that has the mark for the cam pulley? I found some pictures that make it look like I can line the crank and accessory pulleys up with their marks and use a string to line all 4 points of the center of the cam and crank pulleys and their timing marks. Does anybody know if that's right? Here the picture I found (thanks El Pescador):
http://www.threefattigers.com/Protocore/Volvo/TimingMarks.htm
