I have a 1988 Chapparal 2350SX cuddy cabin with a 350 Magnum 270hp and an alpha 1 lower/ new Sterndrive Eng upper drive 1.47 ratio. The boat came with a Quicksilver Silverado 3 blade SS prop 14x19p (cupped). When trimmed out at WOT it is running 5000-5100 rpm @ 47mph. Last year I did see 48.5mph one time but have not been able to repeat this season. On the engine the label says WOT should be between 4200-4600 rpm. I would like more speed to at least see 50+mph. Don't care too much about hole shot- no skiing etc.
Should I change to a 21P-22P prop and what would this do to my RPM and top speed? Would this bring it down to acceptable range and most importantly would speed increase? I have tried all the online calculators and they say my boat should run much faster (54.8 with 15% slip on the 19P) It is a heavy boat at around 4000lbs but it seems like it should do better. Prop slip seems to be an issue for me or at least it seems like it according to the calculators...Any SS prop recommendations or any other easy performance upgrade ideas would be much appreciated...
PS. boat was tuned up new plugs etc. in spring
Thanks in advance,
Bob
Kingston, RI
Thanks in advance,
Bob
Kingston, RI
