  #1
Old August 11th, 2008, 02:48 PM
JT!'s Avatar
JT! JT! is offline
Default 1971 Evinrude 50 - sudden power loss
i have already tried replacing my coils to resolve the problem, but the problem CAME BACK. It did seem resolved with the new coils for about 2 hours.
could i have killed the coil? or can a new sparkplug go bad and stop sparking?
cylinder #1 plug is black & sooty
cylinder #2 plug is 5% sooty and very wet.
if i test the plugs, they both spark.
i can idle, and fast troll without problems. anything over a 1/4 throttle, it just doesnt respond. it doesnt bog. like it did before changing the coils.
oddly, the fuel line primer bulb is very soft, but re-inflates quickly, and pumping it doesnt help in the 1/4 to WOT range.
  #2
Old August 11th, 2008, 04:02 PM
larky's Avatar
larky larky is offline
Default Re: 1971 Evinrude 50 - sudden power loss
If the top plug is black and sooty then I would say that its running too rich. Now I know you have been through a lot with this motor, so you may have already got the carbs set. But the factory setting are just a starting point (imho) try to adjust a little beyond that setting.
You have probably already read this but here it is,
carb settings by joe reeves:
http://forums.iboats.com/showthread.php?t=167352
  #3
Old August 11th, 2008, 08:44 PM
JT!'s Avatar
JT! JT! is offline
back from my days of racing MX and fixing my own bike, i learned the plug should be a dry caramel/golden color.
so i will check my fuel mixture, once its running.
but for now, how to get above 1/4 throttle. i'm still stuck.
  #4
Old August 11th, 2008, 09:26 PM
Redneck1 Redneck1 is offline
I had a '79 70 hp do about the same thing but mine didn't do it as I was running along but same syptoms idled like a champ but no top end and I found out today it was apower pack. The only differance is mine is a 3 cyl.
Rob
  #5
Old August 12th, 2008, 03:49 PM
JT!'s Avatar
JT! JT! is offline
are powerpacks known to have issues only once warmed up?
my condition happens after 5 minutes of WOT and doesnt heal until next time out on water. even with motor off for 2-3 hours while using trolling motor
  #6
Old August 14th, 2008, 12:54 AM
JT!'s Avatar
JT! JT! is offline
took the boat out again today.
i am now convinced i'm running on one cylinder as my top speed is 7mph, no power, no acceleration.
also answers my question about fuel economy, i've been pouring gas thru an unfired cylinder. double the gas and only 25% OF THE POWER... the working cylinder loses its own momentum from constantly compressing the non-firing cylinder
  #7
Old August 14th, 2008, 01:20 AM
Okee Jimmy Okee Jimmy is offline
It sounds like you have a ruptured fuel pump diaphram, allowing fuel to be sucked directly into the crankcase. This would explain the slack primer bulb, high fuel consumption, and sooty plugs.
  #8
Old August 14th, 2008, 01:23 AM
JT!'s Avatar
JT! JT! is offline
thats a very interesting perspective jimmy i will check that first thing in the morning.
do you think its the entire cause of my issues, or just a contributing factor?
  #9
Old August 14th, 2008, 07:24 PM
JT!'s Avatar
JT! JT! is offline
a dead plug!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sudden Loss of Power wolfpaq91 Johnson & Evinrude Outboards 3 July 2nd, 2008 02:52 PM
6hp sudden power loss mefishalotz Johnson & Evinrude Outboards 8 August 30th, 2007 11:16 PM
Sudden Loss of Power - Mercruiser I/O lbirch79 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 August 23rd, 2007 06:30 PM
1987 Evinrude 60- Sudden loss of power jwebb2ni Johnson & Evinrude Outboards 4 June 13th, 2007 12:32 PM
Sudden power loss - 75HP Evinrude wolgemuthg Johnson & Evinrude Outboards 2 August 8th, 2005 07:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
