  #1
Old August 11th, 2008, 02:46 PM
Boscusjamal Boscusjamal is offline
Default 1971 135 Mercury loosing fuel pressure
Hi, I am new to boating and this site. I became the owner of a 1971 MFG Gypsy with 1971 135 Mercury. The motor starts right away and runs on idle just fine I guess. The problem occurs when I apply a load, the motor stalls out unless I pump the fuel bulb. I am loosing fuel pressure. I changed both fuel pump gaskets . Where should I go next, the Carbs? Or are there bigger problems? Also I changed the plugs and it has fresh new gas.
  #2
Old August 11th, 2008, 03:26 PM
Chris1956 Chris1956 is offline
Default Re: 1971 135 Mercury loosing fuel pressure
Check the fuel line for air leaks, especially at the tanks and motor.
  #3
Old August 11th, 2008, 05:52 PM
j_martin j_martin is offline
Quote:
The usual failure in the fuel pump is the little disk valve thingies. How did they look?
hope it helps
John
  #4
Old August 11th, 2008, 08:18 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
If the above good suggestions don't solve your problem, you can can consider troubleshooting with a vacuum gauge. With this gauge, you can test for a fuel line restriction between the fuel pump and fuel tank, a weak fuel pump, or an air leak in the fuel line. Any of these three situations can cause the sympoms you describe. The below linked thread has a guide on how to use a vacuum gauge. The symptoms described in the thread may be different than yours, but the troubleshooting tests still apply.
http://forums.iboats.com/showthread.php?t=261581
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #5
Old August 11th, 2008, 10:59 PM
I will look into all those suggestions thanks for your help and interest
  #6
Old August 11th, 2008, 11:56 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
I'd initially look towards the fuel pump and lines feeding it for air leaking in.
As far as the fuel pump(s) I would probably kit(repair/rebuild using a kit) those with the check valve kits as they come with the diaphrams too.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loosing pressure & gas in fuel pump jazlien Johnson & Evinrude Outboards 5 August 10th, 2008 12:58 PM
1973 EVINRUDE 135 HP - gradually loosing speed on the water BagOFchips3071 Johnson & Evinrude Outboards 6 June 11th, 2007 09:37 PM
Loosing primerv bulb pressure at ball and lost high speed. Mike Giglio Johnson & Evinrude Outboards 3 September 19th, 2005 07:10 AM
Power Trim & Tilt loosing pressure sudden Yamaha & Suzuki Outboards 2 September 7th, 2005 08:44 AM
1971 Mercury 800 Fuel or Fire? roost Mercury & Mariner Outboards 10 June 13th, 2005 05:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
