Re: minn kota 50lb thrust best charging method or extra battery or solar?
Think about it. You motor at full power draws about 45 amps. A solar panel the size of your boat would take a week to charge that battery after just a couple of hours use so that solution is not even worth thinking about. Besides, it would be a target for thieves.
You need one deep cycle battery with the largest capacity you have room for. To charge that battery, you need either a portable "smart charger" that you carry down to the boat and plug in at the dock, or you can install an "on-board" charger that is sealed, stays on the boat, and again, is plugged in at the dock. If you have an outboard engine on this boat, it is obviously a small one and again would not have an alternator large enough to charge that battery. your only other option is to tote the battery to the cabin/house and charge it there with a smart charger.
