  #1
Old August 10th, 2008, 08:13 PM
cherokee1 cherokee1 is offline
Default No start 95 Sea Pro with 200 Mariner
Odd Intermittent Problem
95 Sea Pro with 200 Mariner.
Intermittent No start. No electricity at ignition switch - Nothing.
Both batteries appear to be fully charged. I Switch from One,Two, Both on battery switch under deck by battery box- doesn't change situation. I Manipulate the throttle to make sure nuetral start switch is on - still nothing.
Now here's the odd part.
If I leave for a few hours and come back - it fires right up!
Any hints??
Thank you
  #2
Old August 11th, 2008, 05:45 AM
CharlieB CharlieB is offline
Default Re: No start 95 Sea Pro with 200 Mariner
Poor battery connections, somewhere in the cables at the switch or at the engine.
Disassemble and clean ALL battery cable connections, BOTH ENDS of EVERY CABLE, positive and negative.
Clean, bright, and tight. Use sandpaper, emery cloth, you want shiny clean bright copper/brass.
Afterwards when it cranks and starts every time then spray/coat each connection with white lithium or similar product to seal and keep corrosion to a minimum, making it last much longer before you have to clean them again (eventually, you will).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'95 Mariner Magnum 200 - removed oil injection - warning module question Alabass Mercury & Mariner Outboards 2 February 20th, 2008 09:17 AM
1994 Mariner 60hp Pro Tracker - won't start tcope Mercury & Mariner Outboards 3 April 13th, 2005 05:34 PM
'95 Mariner 200 warning buzzer bamadave Mercury & Mariner Outboards 19 March 31st, 2005 05:07 AM
95' Johnson 200 Ocean Pro plugs AUGIDAWG Non-Repair Outboard Discussions 4 August 12th, 2003 08:04 PM
95' Johnson 200 Ocean Pro plugs AUGIDAWG Johnson & Evinrude Outboards 4 August 12th, 2003 08:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
