73' 40hp evinrude head gasket leaking
Hello All,
I have a 73 40 hp (#40el 73d) that is project. I bought it "running" from a fellow who seems to have patched it together. I did a compression check (with good compression) and when I pulled the tester out, the spark plug threads came with it. I got a new head and gasket. When I torqued it down, water came out of the gasket in a fine spray. I tightened the head slightly and it still leaked. I ordered a new gasket and re cleaned the cylinder face and noticed a very slight "depression" on the surface of the cylinder. Is there any trick to filling the depression? I was thinking of putting a thin coat of JB weld on the cylinder surface in the "depression" and then sanding it off to get the cylinder surface flat enough to hold water. Any ideas? Should I just use some type of super gasket cement instead? It does not seem to affect the compression, just the water side.
Thanks, Tom
