  #1
Old August 10th, 2008, 06:09 PM
apache1875 apache1875 is offline
Unhappy 50 horse mercury outboard does not start
I was changing trim switch on shifter,put set screw in to far. went into switch
sparked and blew lower inline fuse. I replaced fuse, put shifter back together and now it wont turn over. I have good battery.You can hear the click from the choke, but nothing else. please help.
  #2
Old August 10th, 2008, 06:21 PM
Bob37814's Avatar
Bob37814 Bob37814 is offline
Default Re: 50 horse mercury outboard
Just a shot in the dark but have you checked to see that the shifter is in neutral? My quicksilver box does this. There is a hairline in mine between actual neutral and just enough so the safety switch will engage...Wiggle it a little bit back and forth and see if you can get it, Let me know
  #3
Old August 10th, 2008, 06:29 PM
Lightbulb Re: 50 horse mercury outboard
Yes I tried starting it and moving shifter. I also tried swaping a selenoid. It Does turn over by jumping selenoid. This is a 89 mecury 3 cylinder.
  #4
Old August 11th, 2008, 03:37 PM
outhere99 outhere99 is offline
Default Re: 50 horse mercury outboard does not start
My '86 50hsp has a 20amp fuse on the engine as well. It's right next to the starter. Have you checked that? I'm not sure if thats for the starting, though.
  #5
Old August 11th, 2008, 05:09 PM
MadProps MadProps is offline
check to see if there is a neutral safety switch that you may have also damaged
in the shifter
  #6
Old August 11th, 2008, 06:59 PM
lots of boats lots of boats is offline
Take the cowling off, make sure it is in neutral just in case, take the plugs out of the engine, and put them in the boots where you can see them, where they can ground and where they wont bite you, take the yellow black wires from the key kill switch and the safety switch, if there is one, off the CDI box, take a jumper wire and jump the starter like you have been doing. It should crank fast and spark. If it does hook up the switch wires one at a time to see if you can find a ground. The most common problems are the key and the safety or start in gear switches, they are fussy little things and get bumped and corroded.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
4 stroke 50 horse outboard F50TLRY 419312 62Y Jiimi73 Yamaha & Suzuki Outboards 5 June 5th, 2006 03:39 PM
pistons for a 50 horse outboard. rolmops Johnson & Evinrude Outboards 6 April 12th, 2005 03:54 AM
50 horse. mercury will not start Ricky&Lisa Mercury & Mariner Outboards 9 July 8th, 2004 08:39 PM
Pistons for Chrysler 50 Horse Outboard late 60's jljbmill Force & Chrysler Outboards 1 June 14th, 2002 07:23 AM
How to Winterize a 50' horse outboard? NAPCO Non-Repair Outboard Discussions 2 October 16th, 2001 10:18 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
