  #1
Old August 10th, 2008, 04:33 PM
piperdog piperdog is offline
Default mercury ,65 hp ,cant get to drive
hello,ive a blueband ,65hp,1976 outboard .on taking the lower gear case unit off ,i found that there is a safety mechanism that operates via a bar thats on the 2 hooks that goes over the bar that allows you to change the pitch of the outboard,on the lower gear case unit ,when in position it allows a cam to come up,ours doesnt ,is this spring loaded ,(so we turned it arround and can only get forward,no reverse or neutral ),hope i make some sense,,thanks piperdog
  #2
Old August 10th, 2008, 05:00 PM
tredragon's Avatar
tredragon tredragon is offline
Default Re: mercury ,65 hp ,cant get to drive
yes, and had the same problem. Take the cam off the shift shaft it sits on. Put the controls in neutral. Wrap a rag around the shift shaft and turn it with some pliers or vice grips one click at a time, each click checking the prop to see if it spins freely in both directions. When it does, click the shift shaft into forward (you'll know because the prop spins only forward, not reverse) the rest of this post I stole from Emckelvy:
There's a ramp built into the cam and the position of this ramp determines whether the hooks will lock down or release when you tilt up the motor.
The correct placement of this cam is such that, when the lower unit is just about to shift into Neutral (but is still in Fwd), the end of the lockout rod is pointing to a spot about halfway up the ramp. If you look at this while it's apart, it'll be obvious.
I know that you'd typically put the lower unit in Neutral when installing, that's no problem. Just shift it to Fwd, get the shift cam set up correctly and then shift the lower unit to Neutral before you reinstall.
The cam can only go on one way and work correctly. If it's off by one tooth in each direction, you'll know because it's no way even close to being aligned with the reverse lockout rod.
Underneath the shift cam is a plastic thrust washer with some tabs on its sides. This fits with the smooth part up. It's a good idea to grease this area, and the shift cam ramp, with some waterproof grease. Just be sure that if you get any grease on the top of the shift shaft to wipe it off. Grease on top will "hydro-lock" the shift shaft and shift rod when you try and put them together. NOTE: if this washer is missing, the lock may not work correctly.
__________________
1968 15' Larson All American - Lapline Hull
1968 Merc 500 s/n 2344469
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
65 HP Mercury Stumpys Mercury & Mariner Outboards 4 July 11th, 2008 02:52 PM
Trouble with 65 Hp Mercury cdnboatguy Mercury & Mariner Outboards 3 July 3rd, 2007 02:28 PM
72 65 hp hydroelectric drive rsharer Johnson & Evinrude Outboards 8 August 31st, 2004 05:58 PM
65 hp mercury outboard tony luciano Mercury & Mariner Outboards 1 July 22nd, 2002 03:11 AM
65 HP Mercury pyrodad Mercury & Mariner Outboards 2 April 3rd, 2002 06:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
