Hi all, i got a 1960 evinrude motor payed $350 for the boat and motor. At first the motor didnt start but after cleaning the points and changing the gas tank and line, new plugs( well the plugs are a different plug then the ones that were in it) but i bought them from a marina in town that sayed they would work. we took it out today and started right up tok off and it died. started it back up and gave a little throttle and you would hear it start to chug a bit. tryed to give it more throttle just to see and started to chug more. Had a guy at the lake look at it and he sayed that the gas to oil mixture was not enough oil for starters. ( a friend put the oil in so i thought he knew what the ratio was) hmm....
I guess im wondering if and one would know why it bougs down or chugs when given throttle.
again at the start after buying the boat we replaced plugs, checked water & fuel pump. cleaned points and replaced gas tank, line and connectors.
also took off other holes one at a time to make sure they where not clogged and replaced the bad ones.
thanks.
thanks.
