Anyone seen this problem? My tack works normally on start and acceleration but at about 4K is starts going in reverse as I increase the throttle. Don't know if it's related but the tilt guage has also started acting up. Running at normal plane and the tilt meter will suddenly go to full up tilt. Any suggestions would be appriciated.
Stator is putting out 14 VAC @ 1200 rpm, Rectifier diodes check ok and but only reading about 13.2 vdc at the battery.
Thanks,
RJWoody4
Thanks,
RJWoody4
