  #1
Old August 9th, 2008, 12:30 PM
fulmar fulmar is offline
Default '04 Yamaha 225 4-stroke Fuel/ Oil Leaking From Motor
I run twin '04 Yamaha 225 4s on my Regulator 26. When I lower the motors, a fuel/ oil slick comes off the starboard motor. Both motors are still under warranty, but I don't have time to get the motor into the mechanic until next Wednesday since I'm a charter captain, with trips booked up until then. Troubleshooting and repair advice would be greatly appreciated.
  #2
Old August 9th, 2008, 01:43 PM
matt2002's Avatar
matt2002 matt2002 is offline
Default Re: '04 Yamaha 250 4-stroke Fuel Leaking From Motor
Take the cowling off and look for where its coming from as you lower it.
  #3
Old August 9th, 2008, 02:12 PM
Default Re: '04 Yamaha 225 4-stroke Fuel/ Oil Leaking From Motor
Thanks, Matt. I've done that, but can't find the source of the leaking fuel/oil. I checked the lines running to the filter and the filter itself, all seem snug. After taking to cowling off, the motor doesn't smell of fuel. Could the fuel be coming out of the prop? Or could it be a leaky gasket somewhere like the fuel pump?
I don't have a shop manual for the motor thus it's difficult for me to properly diagnose the problem.
  #4
Old August 9th, 2008, 04:01 PM
matt2002's Avatar
they are through prop exhaust but I doubt that would be causing the slick.
  #5
Old August 9th, 2008, 04:20 PM
rodbolt rodbolt is offline
run it till it absolutly pukes and whine cause its down for 3 weeks.
actually as its an EFI motor and no running complaints I would more suspect you have a trim or a tilt cylinder leaking.
however if oil can leak out water can leak in and may or may not be covered as your running with a known problem
making it back to shore with a gimped moter is one thing, being so irresponsible to take paying passengers out with a gimper is another thing entirely.
there really isnt much the average backyard joe can do with an F250.
its simply fairly complex and not much in the way of user servicable stuff.
if you have a fuel rail pressure tester and the diagnostic test lamp you can look at a few things but not much.
  #6
Old August 9th, 2008, 10:47 PM
Default Re: '04 Yamaha 225 4-stroke Oil/ Fuel Leaking From Motor
Thanks, Rodbolt, I appreciate the help. Do you think a power trim and tilt leak could create a 5' - 10' radius slick around the motor? It only happens when the motors are down. When I tilt them back up, it goes away.
I re-checked the fuel lines inside the cowling. All seem snug and I didn't detect any leaks. Neither motor smells of fuel inside the cowling. I also checked for fuel on the outside of the motor, below the cowling where it could leak down if it was indeed an issue with something near the powerhead. I didn't feel, smell, or see any fuel around that area.
I may be able to get the boat to a Yamaha dealer on Monday, at least for some diagnostic work. Surprising that motors that new could spring a power trim and tilt leak, though I guess they have sat in the salt for awhile. Thanks again.
  #7
Old August 10th, 2008, 01:21 PM
matt2002's Avatar
You could have a lower unit leak.When was the last time you had the prop off and checked for mono wrapped around the prop shaft ?
  #8
Old August 11th, 2008, 10:08 AM
I spoke with a yamaha mechanic this morning, he mentioned the slick could be caused by how the oil filters were changed. Apparently, if the tech doing the filter change doesn't place rags under the filter prior to the change, oil will seep down forming a slick. It builds up over time and takes awhile to go away. To resolve the sick issue, you take the covers off the motor and clean around the inside where the oil seeped down.
The mechanic had heard of this happening before on a 26' Regulator which was serviced at the same place I bought the boat (used). Must be a tech who isn't properly replacing oil filters.
  #9
Old August 21st, 2008, 07:25 AM
The slick wasn't caused by a fuel leak after all, nor was it lower unit or power trim/tilt related.
It's a bad crankshaft seal. This is bad news since I will now be without my boat for a long time and I'm in the middle of my busy bluefin season. I have a SeaCraft as a backup, but my clients expect the Regulator.
Any idea how long the repair should take? The Yamaha dealer said it's a huge ordeal which may take weeks. I don't have weeks. At least the motors are under extended warranty.
  #10
Old August 21st, 2008, 08:49 PM
on some high hour motors we have seen the driveshaft seals leak oil where the shaft passes through the oil pump.
it can be fixed in a couple hours with a 30 dollar speedi-sleeve on the crankshaft.
yep, sometimes a tech can spill oil, its not like they made it easy for the filter removal.
we made some stuff that works well with the motor tilted up.
the pump seals are about 150 and the pump is about 450.
warrenty may or may not cover it when they ask for the hours then ask if its commercial or not.
best advice is to remove any and all indications of commercial use if they are registered as pleasure.
I already busted one guy for that.
the yamaha RTA asked me point blank on the phone if it was commercial or not, I had no choice but to tell him yep there is a for hire license on the side.
  #11
Old August 22nd, 2008, 05:39 PM
Thanks, Rodbolt. For future reference sake, I'll keep this thread alive. My motors have just over 600 hours on them, were manufactured 9/03, and have the y.e.s. warranty until 4/09. I don't know their history all that well, as my boat had a previous owner. I do know the only history of warranty repair on the motors was a recall in early '04. I have only put about 60 hours on the motors since I bought the boat a month ago.
The Yamaha dealer who services my boat is telling me Yamaha didn't even flinch at their request to perform the warranty work, they immediately gave them the go-ahead, not only for the leaking starboard motor, but also for the port motor, which I haven't had a problem with as of yet. Yamaha requested the dealer to install a new powerhead in both motors. From what the dealer said, it sounds like Yamaha knows all about this issue and is trying to resolve it. Only problem is parts are difficult to come by including the new powerheads. According to the dealer, Yamaha may be re-engineering the faulty parts, thus the hold up.
I hope this doesn't happen to many other unsuspecting Yamaha owners, I have yet to see the light at the end of the tunnel, not sure when my motors will be finished. On one hand, it's great to have new powerheads, on the other, I'm going to be without a boat for a long time during the busiest time of my fishing season.
I'll keep the forum updated as work progresses.
I must say, Cape Ann Marine in Gloucester, MA (the dealer who's performing the work) has been incredibly great to deal with. I highly recommend them to anyone looking for excellent service.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'98 Yamaha 250 Fuel Injected v. Y 225 4 Stroke barliboy Yamaha & Suzuki Outboards 3 July 11th, 2008 01:19 AM
2005 Yamaha 250 4 Stroke-Hi Pressure Fuel Pump Its4Reels!-Parker23 Yamaha & Suzuki Outboards 10 June 10th, 2008 09:06 AM
Yamaha 250 four stroke youngnapoli Yamaha & Suzuki Outboards 3 September 25th, 2007 07:32 AM
Yamaha 250 4 stroke fuel pumps Tottally Tuna Yamaha & Suzuki Outboards 3 November 13th, 2006 07:57 PM
Yamaha 250 Four Stroke Won't Start Windfall Yamaha & Suzuki Outboards 2 July 4th, 2005 07:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
