  #1
Old August 9th, 2008, 07:43 AM
MUDWISER316 MUDWISER316 is offline
Default 2000 150 Mercury Steering Problems
I bought my boat about 5 months ago found out steering cable was in need of replacement (cable was tight even when disconected from motor) . No big deal! Well last week I broke the helm trying to turn the motor. time to replace helm and cable which is a telflex system. well come to find out the motor is locking up on me too!. I have greased the motor about 3 times since i've had the newer motor on the boat. I greased the motor today trying to get it to free up but it not working. the grease point is only 2 inches from the top of the pivit section but i'm only getting grease to come out from the bottom and none from the top which is were i think it locking up at. I even tried wraping the bottom section to stop the grease so it would push the old grease out the top but it did not work. Any help or ideas on this subject would great! I've looked through past steering threads and post with no good input for my problem. Thanks in advance! MUD!
  #2
Old August 9th, 2008, 08:14 AM
Chris1956 Chris1956 is offline
Default Re: 2000 150 Mercury Steering Problems
Mud, Tilt the motor up all the way and see if you can lift it up on the steering shaft to close the bottom bushing space and open the top bushing space. I tied a rope around the AV plate and twisted the rope with a stick to make it tight like a touriquet. That lifter the motor on the shaft and allowed the grease to come out the top bushing. If that doesn't get it, you can try some heat on the upper bushing to melt off the old grease.
  #3
Old August 9th, 2008, 04:48 PM
I tried useing some cheese cloth on the AV plate as a touriquet. I'll try using rope this next time. I tried to get the weight off the av plate so I could move the motor up with no luck. As for tilting the motor up it can only go so high be for it hits the back of the boat due to the gell bracket set up. I was hoping the stay away from using heat being I don't want to burn off the paint. It does seem that i'm going to have to give it a try I need this thing to loosen up! Thanks! Chris 1956
  #4
Old September 27th, 2008, 05:58 PM
peterholaway peterholaway is offline
Mud, let me know if you had sucess. I have exact same problem on my Black Max 150. Pete
  #5
Old September 27th, 2008, 07:08 PM
  #6
Old June 4th, 2009, 11:21 PM
We had very little sucess! We used rope and heat nothing worked. we pulled the power head off and pulled apart the sections of the motor and motor mounts. it was not the funest thing i have ever done! we had to purcase a new steering shaft and arm. this thing was about $500.00. OMG! the shaft itself is now made out of stainless which is nice. BUT! They are still using regular steel for the rest of the unit which does not help on rust issues where it counts! total cost for us to fix this was about $900.00 after replacing steering shaft, studs, bolts and gaskets. sorry it took so long to up date!
  #7
Old June 4th, 2009, 11:42 PM
j_martin j_martin is offline
Quote:
Moral of the story...........
Grease is cheeper than parts.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 Merc 150 FEV problems Matty J Mercury & Mariner Outboards 3 May 26th, 2008 08:15 PM
2000 johnson 150 ficht problems peteb Johnson & Evinrude Outboards 0 July 17th, 2006 08:57 PM
2000 Yamaha 150 Idle Problems johnsonhd Yamaha & Suzuki Outboards 0 June 25th, 2006 01:42 PM
2000 Johnson 150, all 4 have the same problems mirage2521 Johnson & Evinrude Outboards 2 September 28th, 2005 08:00 PM
2000 Suzuki 150 DTC problems fordtrbo Yamaha & Suzuki Outboards 3 January 24th, 2005 06:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
