  #1
Old August 8th, 2008, 09:11 PM
gulfcoastie gulfcoastie is offline
Default CARB problem? 1997 MERCURY 150 XL OUTBOARD
When I drop the throttle on my 1997 MERCURY 150XL OUTBOARD (VRO system has been removed) it hesitates a few seconds and then takes off. Mid-range and top end are fine, this problem only occurs if the engine has been at idle or shut off for more than ten minutes. The problem does not occur if I prime the bulb every time I go to get on plane.
2nd question: when engine is tilted all the way up and I prime the bulb fuel leaks out the carb, is this normal?
Thank you.
  #2
Old August 8th, 2008, 09:34 PM
Ed R Ed R is offline
Default Re: CARB problem? 1997 MERCURY 150 XL OUTBOARD
hey! sounds like carbs need to be cleaned out , and float height needs to be adjusted.
  #3
Old August 8th, 2008, 10:57 PM
j_martin j_martin is online now
Thank you.
It's pretty normal for the carbs to leak when it's tilted all the way up. You have an open top (the vent) bowl full of fuel.
You might have a weak fuel pump or a very small air leak in the fuel line between the tank and the fuel pump. (including the connector)
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 150 Xl Overheating AO Mercury & Mariner Outboards 12 May 21st, 2009 10:28 PM
2002 Mercury 150 xl swb Saltwater vrb404 Mercury & Mariner Outboards 1 June 6th, 2008 08:37 PM
mercury 2000 150 xl sw tilt problem Davetbird Mercury & Mariner Outboards 3 June 5th, 2006 08:39 AM
Input on 2001 Mercury 150 XL? patrickh Non-Repair Outboard Discussions 4 September 2nd, 2004 02:41 PM
1997 25hp mercury outboard starter problem kd5jnl Mercury & Mariner Outboards 2 October 18th, 2003 04:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
