Hello all experts, some good advice needed here...
'86 Johnson 70 vro has some problems when cold:
- Starts well for being that old piece.
- Dies instantly when putting into gear! Needs excessively long warm up on slightly higher idle (about 2 minutes or so) before it can be set to normal idle and get going somewhere.
- When warm the idle is ok (slighly higher compared to cold engine) and the engine does not stall.
- Runs well on any throttle level except for that cold idle.
- Spark plugs have been renewed by an authorized service partner, so I think they're ok.
Any ideas on what to check/do to get the cold idle a bit stronger???
A little worried about the vro-unit also - being that old. Should I try to purchase a new replacement? Where do I get i cheapest? I've done some engine work with smaller engines so I think I could do the replacement myself
rolleyes
Thanks in advance!
Thanks in advance!
