I have a 115HP rude that under the muffs overheats in about 5 minutes, there is a stead stream of water that is being pumped out and say every minute or so it will stop for a spit second and then spit strong again. Now the starnge thing is the water coming out alternates from hot to cold on and off. Would this be the cause of a old/bad water pump or would you lean more towards the thermostats?
Thank you for any help you can loan.
Jeremy
Jeremy
