  #1
Old August 6th, 2008, 02:10 PM
steve62 steve62 is offline
Send a message via Skype™ to steve62
Default '77 Evinrude 55HP no reverse
When I place the boat in reverse it just clicks, the prop will turn but not enough to move the boat.
When out of the water I can sometimes get it to go into reverse (engine not running) and turn the engine over by hand by turning the prop. Maybe one out of ten tries. The cable appears to be adjusted ok. The lever is as far back as it'll go..... It should be in reverse.
Is there another adjustment inside the leg or is the bottom pooched?
__________________
If it ain't broke...fix it til it is!
  #2
Old August 6th, 2008, 04:46 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: '77 Evinrude 55HP no reverse
Did you or anyone else have the lower unit off and turn the shift rod out of adjustment? That measurement from the top surface of the lower unit to the center of the shift rod hole IN NEUTRAL is critical. See the following if this has taken place.
1977 - 1981 - 50, 55hp Manual Start = (S) 16-23/32 - - (L) 21-23/32" plus/minus 1/32" Have the shift rod in neutral and the offset to the rear
  #3
Old August 7th, 2008, 01:35 AM
Hmmm, I know I haven't had the lower unit off. Is there something else that could be causing this? I'm unsure what your (s) and (L) mean...
It does seem like it's just not getting all the way into reverse... What's involved with adjusting this shift rod? Besides I assume removing the lower unit
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
77 55hp Johnson Jrock 5877 Johnson & Evinrude Outboards 1 July 16th, 2008 07:45 AM
70s -- 55hp evinrude - reverse forward issue casi77 Johnson & Evinrude Outboards 10 February 28th, 2008 10:21 AM
69 evinrude 55hp reverse Kajun37 Johnson & Evinrude Outboards 6 January 17th, 2007 08:17 PM
'69 Evinrude 55HP w/ Selectric switch will not reverse kauboy Johnson & Evinrude Outboards 30 September 1st, 2006 11:28 AM
77 55hp Envirude aloha55 Non-Repair Outboard Discussions 2 May 27th, 2002 08:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
