  #1
Old August 6th, 2008, 10:20 AM
Crestliner2007 Crestliner2007 is offline
Question 2006 Yamaha 15 HP outboard - carb
Bought this engine brand new in 2006 and have used it during the open water season, here in MA, each of those years, including this one. Spring of 2007 I installed a water separator (10 mc Yama filter). I usually disconnect the portable tank each winter and use the residual fuel in my snowblower. BUT, I have never run the carb dry when putting my boat in storage. This coming winter I was thinking about doing that, before fogging the cylinders. I would accomplish this using a barrel of water, which I use for testing the engine prior to launching each spring.
1) Is this a good/bad idea (drying up gas in the carb)?
2) Should I do something else, to clean the carb after running it dry? Especially since I've never done anything to date.
3) If I follow the same procedure as in previous years, will I loose HP due to gas gunk buildup in the carb, as time goes by?
THANKS!
  #2
Old August 6th, 2008, 12:08 PM
JB's Avatar
JB JB is offline
Default Re: 2006 Yamaha 15 HP outboard - carb
4 Strokes don't depend on fuel for lubrication, so I don't see a hazard in running a single carb 4 stroke dry for storage. For really long term storage there might be some risk of drying out internal gaskets and seals, but I see that as an acceptable risk to avoid varnish.
4 Stroke carbs don't suffer nearly the varnish buildup that mixed fuel burning 2 strokes do. I never considered it a problem.
It is a good idea to always run Stabil or other fuel stabilizer in your gas.
Good luck.
__________________
RED SKY at night. . .
JB
  #3
Old August 7th, 2008, 12:22 PM
triumph190 triumph190 is offline
Running the engine until dies will not get all the gas out of the carb. If you are going to run the gas out be sure to drain the carb or you will have gunk buildup in the carb. I don't recommend that you run the gas out. Put sta-bil in the gas tank and run the motor so that the sta-bil gas gets completely trough the engines fuel system. This will keep the carbs from tarnishing or guming up and remove any gunk buildup that may already be present. It will also keep all seals and gaskets moist so they don't dry rot, crack and leak.
Sta-bil will keep fresh fuel good for up to 24 months.
  #4
Old August 10th, 2008, 03:22 PM
Will Sta-Bil work with gas containing 10% Ethanol? My marina says it won't!?
  #5
Old August 11th, 2008, 01:40 PM
Yes, stabil will work fine with gas containing ethanol. In fact it is recomended that you use stabil with gas containing ethanol. Ethanol attracts water and the stabil prevents water from getting into fuel.
http://www.goldeagle.com/sta-bil/stabil_marine.htm
  #6
Old August 11th, 2008, 04:03 PM
Silvertip Silvertip is offline
An even better product is SeaFoam which is available at the same places you buy Stabil. I won't delve into the scare tactics used by marina operators as it only makes my blood pressure rise. Treat the fuel, and go boating. Stabilize the fuel when finished for the season and put the boat to bed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2006 Honda 75 hp outboard performance Daboat Honda & Tohatsu/Nissan Outboards 4 July 23rd, 2008 05:37 PM
2006 yamaha f-15 power problems thompson stealhead Yamaha & Suzuki Outboards 2 July 29th, 2006 05:33 AM
best place to sell my 1976 9.9 outboard and a 15 hp carb? ntoracn@yahoo.com Johnson & Evinrude Outboards 14 July 3rd, 2005 04:36 PM
repairing or taking carb out of 15 horse yamaha 2stroke tamster61 Yamaha & Suzuki Outboards 3 May 18th, 2005 06:37 PM
1994 Yamaha 9.9 hp 4-stroke outboard carb Dr. David A. Johnson Yamaha & Suzuki Outboards 1 August 31st, 2003 02:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
