  #1
Old August 6th, 2008, 09:58 AM
mad151 mad151 is offline
Default Evinrude 6 HP...gearcase lube
Hello all,
Just wanted to get some advice on what type of gear oil I should use in my lower unit. (Evinrude 6 h.p. circa late 60's early 70's)
Does anyone have the link to a iboats page that I could use to find out the year of my 6 hp. I'm estimating late 60's early 70's
Was there a certain year that Evinrude changed to using different gear oils? If so does anyone have data on these increment of years and what they recommended for each evolution of motors?
Thanks.....
  #2
Old August 6th, 2008, 10:08 AM
ezeke ezeke is offline
Default Re: Evinrude 6 HP...gearcase lube
The model number should be located on a 1" X 3"+/- aluminum plate located on the port transom bracket. Failing that, it may be stamped on a nickel sized convex welch plug on the engine block. The model number can be translated by the OMC archive chart found here:
http://web.archive.org/web/200112230...odyr/EHP6.html
  #3
Old August 6th, 2008, 02:03 PM
Thanks for the help!
  #4
Old August 6th, 2008, 06:59 PM
When the 1965 6HP models came out, they were using OMC type C oil in the gearcase. That has since been superseded by not a few other high viscosity marine gear oils, all of which are suitable as long as they are high viscosity marine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Starflite Engine and Gearcase lube english 79 Johnson & Evinrude Outboards 1 April 27th, 2005 09:22 AM
Gearcase lube ?? Cortes165 Johnson & Evinrude Outboards 7 September 19th, 2004 02:57 PM
gearcase lube waterbill Yamaha & Suzuki Outboards 1 March 24th, 2004 05:26 PM
1969 - 6 HP Evinrude Gearcase Lube citom Johnson & Evinrude Outboards 2 June 13th, 2002 04:05 AM
Evinrude, 18hp (Fastwin) 1971- Gearcase Lube? Wayfarer Johnson & Evinrude Outboards 1 November 18th, 2001 11:47 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
