Re: 1979 mercury 115 hp stuck in reverse
you should be able to shift the lower unit into neutral by moving the linkage by hand, yes. Then put the controls into Neutral and adjust the cable's locknut/adjustment nut until you can re-attach cable without moving linkage. Make sure prop is spinning in both directions very freely to ensure you are in neutral in the lower unit. After reattaching cable, shift controls first into forward, check prop spins forward only, then reverse, checking prop again for reverse only spin.
__________________
1968 15' Larson All American - Lapline Hull
1968 Merc 500 s/n 2344469
