  #1
Old August 6th, 2008, 02:36 AM
boat1031 boat1031 is offline
Default Mercury 9.8 not pumping water
I have a merc 9.8 mid 80s. I Started it out of water for about 20 seconds & burned up the pump. Replaced the pump but it is not pumping water thru the motor & out of the little hole at top right of motor. I can put the ears on the flush hole with the hose running & water comes out of the little hole just fine. I have flushed & backed flushed numerous times with air & water thinking there was old impeller parts stuck. I forced water up the copper water line into the motor where the pump would normally pump it, but I cannot get it to flow thru. I suspect something is plugged but dont know where. Any body got any ideas. Thanks for any help
  #2
Old August 6th, 2008, 04:22 AM
miker-gr's Avatar
miker-gr miker-gr is offline
Default Re: Mercury 9.8 not pumping water
are you sure you place the pin that holds the impeller correctly?
Because it happened to me once
  #3
Old August 6th, 2008, 11:05 AM
Thats not the problem, I checked & it is in place. But thanks anyway
  #4
Old August 6th, 2008, 11:16 AM
8075mercury 8075mercury is offline
At the top of the copper tube under the powerhead, there is a plastic washer and rubber seal. If you can not get water through the copper tube, it is possible that it is plugged at that point. Also broken pieces of pump impeller can plug there too. To get to that point and clean it out, you will need to remove the lower cowling and take the powerhead off.
If you want to clean out the rest of the system while you have the powerhead off, remove the exhaust cover and baffle plus the cylinder block cover. Be careful unbolting these covers as it is easy to break a bolt off.
Good luck and great little motors!
  #5
Old August 6th, 2008, 11:28 AM
I will try that. Thanks for the help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard not pumping water mwrBoat Mercury & Mariner Outboards 3 June 23rd, 2009 01:11 AM
7.5 mercury (no water pumping) 308user Mercury & Mariner Outboards 7 April 23rd, 2007 11:25 AM
2002 MERCURY 125 NOT PUMPING WATER ROBERTSTELLJR Mercury & Mariner Outboards 3 June 19th, 2006 01:35 PM
water not pumping mercury burtinski Mercury & Mariner Outboards 1 April 15th, 2003 05:34 AM
Mercury 50 Overheating - No Water Pumping!! Jonathan Morley Mercury & Mariner Outboards 3 September 11th, 2002 02:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
