I have a 72 mercury 1150, can someone help me to understand exactly what this means.
"When the throttle is in the idle position the carbs should be fully closed and the ignition retarded. It is the amount of retardation that determines your idle speed and is set later with the idle stop screw."
when it says ignition retarded is that 0 deg? right now I have mine set at 0 deg when the throttle is in neutral, 4 deg primary advance, secondary advance just touching before economizer collar, 21 deg max advance
any help would be great, thanks, J
