Re: Mercury 50 hp starting problems
Could be getting too much fuel (little dishes keep trying to fill when full (foam floats? Bad needles and seats?)), not enough spark (fouled plugs) or incorrect spark timing, or my least favorite...no/very little compression. Don't use starting fluid, it causes a whole host of problems, including big backfires if ignition timing is way off, and considering you're looking into the carbs..that would suck.
Ian
