89 mercury 115hp, is there a missing linkage????
KenStone
I would think i would need some type of linkage from the carb sinc bar to the throttle bar so when the throttle is engaged that it works the carbs... I just need to know before i put it in the water to go nowhere....
j_martin
Re: 89 mercury 115hp, is there a missing linkage????
It's probably cam operated. Disconnect the throttle cable and swing the throttle arm and see what happens.
A factory manual would help, complete with pictures.
hope it helps
John
