Re: How do i hook up the battery
haha please dont hook the positive directly to the starter, you wont like what happens, look for the cable coming from the starter, it should be red or where it hooks up to the starter it will be insulated from ground, that is you positve after solenoid cable, if you trace that back from the starter you will find a little device known as the solenoid, there should be one loose nut where you can attach your positive battery cable, ok that was all for the positive, negative is much simpler, just look around on the engine block until you find a loose bolt, chances are whoever took it off only screwed it back in a turn or two, but really as long as you make a strong ground you should be ok. good luck
