  #1
Old August 5th, 2008, 02:31 PM
MuskieOn MuskieOn is offline
Default Run fuel out of a Yamaha 25h 4 stroke
Question
I have a 2006 Yamaha 25hp 4 stroke due to surgery two weeks ago and the Dr. tell me I won't be doing much fishing for 4-6 month I have this question.
The outboard has a connection to hookup a garden hose. Can I run the motor out of fuel using that connection? I'm not sure if the motor should run while connected to it? I have some friends that are willing to help put the boats up for the winter.
Please help
  #2
Old August 5th, 2008, 05:17 PM
triumph190 triumph190 is offline
Default Re: Run fuel out of a Yamaha 25h 4 stroke
I think the connection you are talking about is to flush the lower unit and is not intended for running the motor with a garden hose. If you want to run the motor with a garden hose get you a pair of ear muffs.
As far as running the engine out of fuel, I personally do not think it is a good idea. One reason is that the tank will go empty before the engine stops running. This means that your pickup line is still sucking and will suck up all the dirt an debris that is inside your tank. The second reason is, seals and hoses will dry out and over time will start to leak.
The best thing to do is fill the gas tank and add sta-bil. Filling the tank will limit the space that condensation has to form. Then run the engine so that the sta-bil treaded gas gets completely through the fuel system.
  #3
Old August 6th, 2008, 01:40 AM
lots of boats lots of boats is offline
Hi
Hook up the garden hose and see if water comes out the pee tube, if it does then the block is full of water and you can run it. You only need to flush the engine with fresh water if you ran it in salt water. Long term storage is a separate issue, most of the worry is fuel oxidation in the carb and condensation in the engine. You can spray a storage seal spray directly into the intake or into the carbs on most engines if you remove the air box first. This just coats everything inside with oil. You can drain the carbs and filters usually with a screw on the float bowl, or filter, or unscrew the filter and dump it.
Cheers
  #4
Old August 6th, 2008, 11:57 AM
hendu3270 hendu3270 is offline
The hose hookup you are referring to is intended to flush your motor. It's how I flush mine after use in salt water. I have a Yamaha 15hp 4 stroke.
  #5
Old August 7th, 2008, 08:42 AM
rodbolt rodbolt is offline
why not simply drain the carb using the fuel bowl drain?
you wont ever run the carb dry,maybe low enough on fuel to shut the engine down but that last 1/4" in the bottom of the bowl will turn to goo.
you may also wish to pick up some crankcase store-N-start to aide in protecting other engine shiney parts such as camshafts,followers and cylinderwalls and such.
what your trying to accomplish is keeping the fuel system and the engine shiney parts from oxidizing.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'95 Yamaha 25h-shift rod 424fr Yamaha & Suzuki Outboards 3 November 20th, 2009 06:13 PM
Is it ok to run out the fuel in a 2 stroke? teslaman Johnson & Evinrude Outboards 9 March 25th, 2007 10:42 AM
yamaha 25 2 stroke wont run BeerCanBobsta123 Yamaha & Suzuki Outboards 4 February 11th, 2003 08:09 AM
'92 yamaha 4Q two stroke. Won't run when throttle is returned to idle. Ken Sadlier Yamaha & Suzuki Outboards 1 November 11th, 2002 08:21 AM
1994 Yamaha 115 Jet Drive: What octane fuel to run? Brase Bear Yamaha & Suzuki Outboards 1 June 2nd, 2002 06:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
