Re: Fuel Problem 1977 Evinrude
If squeezing the primer bulb makes the engine run good then I would suspect the fuel pump as the problem, the rubber diaphrams can get stiff over time and some will even stretch, either case will cause the pump to not pump the required fuel. A fue pump issue will often show up first at slowers speeds because the pump has fewer crankcase pulses to operte on. By squeezing the primer bulb you have in effect become the fuel pump
__________________
"It's no fun if the boat don't run!"
