Timing retarding instead of advancing.
Darcy
OMC 5.0 Chevy 1986. Can't find an answer with search...
I adjusted the timing to 13` BeforeTDC at 500 RPMs. When I idle up to about 2000RPM, the timing is retarding to about 20` BTDC.
Could I have put my advance weights on upside down or something, or is 2k still to low for the advance to kick in and I'm just seeing walk?
Thanks!
Darcy
Darcy
Re: Timing retarding instead of advancing.
I just read some more threads, and now I feel silly! Look like it is functioning as designed. I didn't realize that 30BTDC was more advance than 13.
Ayuh must start harder than 'ell....
Most SBCs are timed to 6?, or 8?, or maybe 10?BTC....
