  #1
Old August 5th, 2008, 06:07 AM
geetee50 geetee50 is offline
Default Mercury Switch Box Proplems?
Hello i have a 15hp 1989 mercury, i've no spark on my bottom cylinder, it starts but runs rough, i've tried the coil on the top cylinders green/yellow supply wire and the coil sends a spark, the compression is 120 on both cylinders, could it then be the switch box? Would any one have some advice please on other options or what to test.
  #2
Old August 5th, 2008, 09:19 AM
Kev144's Avatar
Kev144 Kev144 is offline
Default Re: Mercury Switch Box Proplems?
Ill give ya some advice that I learned the hardway when i was new to outboards (still kinda am). I had a problem with mine not idling. Did some tests and was weak from the switch boxes. I replaced those and same problem. Turned out to be a stator and something i should have checked in the first place as the source then if that checked out, my next option would be the boxes. Just a FYI anyhow to you.
  #3
Old August 5th, 2008, 09:53 AM
lots of boats lots of boats is offline
Hi
Switch boxes seem to just quit, no middle ground. Sometimes when you disconnect and reconnect things you solve the bad connection problem, two simple places to suspect are the ground from the coil, and the high tension lead connection inside the spark plug cap. Try all the little things first.
Cheers
  #4
Old August 5th, 2008, 06:27 PM
kellyisu kellyisu is offline
You should do an ohm reading on both the switchbox and the stator to save you money and time. Good place to start your troubleshooting.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp mercury switch box Jerryiius Mercury & Mariner Outboards 4 August 1st, 2008 09:03 AM
Mercury 80hp switch box spd3853 Mercury & Mariner Outboards 2 June 15th, 2008 03:07 PM
mercury 9.9 switch box yoeman Mercury & Mariner Outboards 1 July 22nd, 2007 06:13 PM
1968 mercury inline 6 switch box starcar331 Mercury & Mariner Outboards 1 May 26th, 2007 01:19 PM
72 80hp mercury switch box? onurneez Mercury & Mariner Outboards 9 September 6th, 2006 09:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
