Re: 2-stroke oil quality
Just buy OPTI2 synthetic 2 stroke oil you run the same mix (follow the instructions on the packaging) in all 2 stroke engines (air or liquid) (chain saw, weed wacker or boat). It burns much cleaner, much less fouling and provides better protection.
http://www.opti2-4.com/
That's really bad advice you're putting out, there. Run that stuff in an older engine at the ratio they recommend and you'll burn the plain bearings out in short order.
Advice given on this forum should be conservative in nature. Outboard motors have their own recommendations, and the use of oil touted on some website for use at the same ratio with all 2-stroke engines, whether air or watercooled, is just flat not a good idea.
TC W3 oil is available everywhere, in several different price ranges. It is designed specifically for water-cooled 2-stroke outboard motors. Recommending something else is tantamount to advising people that destroying their engine is a good idea.
Maybe that oil you're touting is just fine, but who's to say? Use it in your own outboard, if you wish. But please don't recommend it to others. You have nothing to lose if their outboards are ruined.
I am certain of one thing. Using the oils recommended by the outboard manufacturers will not damage their outboards. Using other oils is a crapshoot.
Please don't make such recommendations.
