79 , 85hp Evinrude Dying
Joe Reeves
Re: 79 , 85hp Evinrude Dying
Try pumping the fuel primer bulb..... does that help?
Does the fuel primer bulb go flat when that problem appears?
Does the engine die out gradually OR shut down instantly like you turned the key off?
tashasdaddy
are you saying it would not turn over until it cooled down some? would the starter try to turn the flywheel and could not turn it?
