  #1
Old August 4th, 2008, 03:14 PM
saltshaker saltshaker is offline
Default 225 evinrude shifting
sounds like i may have a simial problem to some already posted here.
I have a 1989/1990 Evinrude 225, been running great. Was about half throttle getting up on plane a week ago, a minute or so later, i was stopped in neutral. seems like all of a sudden the engine shifted to neutral, but the trottle was still "forward". The engine was still running, pee hole working, everything looked normal. shut down the engine, lifted it, no visible damage (i'm pretty sure i didnt hit anything). i dont even think i heard a noise, just slipped into neutral or, slipped out of gear. Looked at it closer the next day, shift rod looks fine, moves up and down. Engine runs fine, but would not go into forward or reverse. Throttle shifts, engine will not start with throttle in gear, so its like the engine knows its supposed to be in gear, just doesn't actually engage.
i'd like to haul the boat and drop the lower unit myself to see what im dealing with. is it very difficult? can someone recommend a book for this, seloc? i figure worse case im looking to replace the lower unit. but maybe it could be a quicker/cheaper fix?
I appreciate any responses, thank you.
  #2
Old August 4th, 2008, 03:47 PM
ezeke ezeke is offline
Default Re: 225 evinrude shifting
I would recommend that you get the OMC factory manual. It will cover the 90 degree Looper motors for your year and provide detailed instructions. You can get them [edit] online, or perhaps find a good used one on Ebay. They are worth the price.
The following link is to a listing for the correct manual for a 1989 looper. The price is excellent:
http://cgi.ebay.com/ebaymotors/Evinr...1.c0.m14.l1318
There is a good chance that the cause of your problem is a spun prop.
You can check it without removing anything by scribing a line as shown in my thumbnail, using the cotter pin as a pointer. If it moves out of alignment you would need a new hub in the propeller.
  #3
Old August 4th, 2008, 04:08 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
you can also disconnect the shift cable at the motor and see if it will go into gear, could be broke cable, in the sheath. or broke in the controller.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old August 4th, 2008, 04:50 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
If the shift rod moves up and down when the control is moved that eliminates the cable and control. Let's hope it's as simple as a spun hub. Since the motor was still pumping water that eliminates a drive shaft break or spline issue above the pump.
  #5
Old August 4th, 2008, 06:02 PM
Thanks all, i just dont see how it could be as simple as a spun hub, or maybe im misunderstanding a spun hub. thats what alot of people have told me. i took the prop off and everything looked good. that would be great if it is the problem. but i would think i'd hear some sort of shifting noise in and out of gear. i do have a spare prop, so if i put that one, that should eliminate the 'spun hub' theory, correct? if its that simple, great!
  #6
Old August 4th, 2008, 06:07 PM
We're hoping it's a spun hub. Does the propshaft spin at all?
  #7
Old August 4th, 2008, 06:13 PM
LOL, i hope its spun hub too.
i did disconnect the linkage at the motor tashasdadday (was hoping it was just a cable disconnected or adjustment), everything looks to move ok. so, with a spun hub, if i lifted the engine a little, and engage the gears, should i see the proft shaft turn in gear? with the motor off, the prop just spins freely both ways in neutral fwd and rev. there is a slight bit of clunking when i turn it backwards. not sure how else to describe it, but, i wouldnt really call it resistance, and it doesnt really make a noise.
thanks
  #8
Old August 4th, 2008, 06:15 PM
i might add, yes, the prop shaft and prop all look to turn as one.
  #9
Old August 4th, 2008, 06:16 PM
Bummer. We'll assume that when you say the prop turns freely the shaft is moving with it. In that case it looks like we'll have to get into the case a little farther. Once you get the boat out of the water, drain the gearcase.
  #10
Old August 4th, 2008, 06:23 PM
yep, shaft moves too. by looking at it, it looks to all be ok. so i think im looking at least to haul and remove the lower unit. i guess i could try my spare prop for the heck of it. so, once i do pick up a manual, is dropping and replacing the lower unit very difficult?
  #11
Old August 4th, 2008, 06:42 PM
Buy the manual I found for you on Ebay. It is the right one, published in 88 for the 89 models that came out in the fall of 1988. That's 1/3 of what a new one will cost you including the postage.
If you are anywhere near I have two spare drives so you don't have to waste what's left of the season.
Dropping the lower unit is 45 minutes tops if you split the lower cowl and take it off. It makes it much easier to replace the unit as well.
  #12
Old August 4th, 2008, 07:17 PM
Thank you, I'm in boston. So if the motor seems to be running ok otherwise and I can swap the lower unit, do you think that will cover me? Based on what I've described?
  #13
Old August 4th, 2008, 08:10 PM
Yes. The main thing is to keep the time of year in mind. If you have to get the gearcase worked on, this is the worst time to do it because everyone is swamped.
Use Personal Message by clicking my user name if you want to talk about it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Evinrude 225 shifting problem mako231 Johnson & Evinrude Outboards 15 July 16th, 2008 07:41 PM
shifting problems 1990 225 johnson SkintBack101 Johnson & Evinrude Outboards 3 August 13th, 2007 04:17 PM
mercury optimax 225 shifting prob. mchales navy Mercury & Mariner Outboards 4 October 7th, 2005 12:28 PM
1993 Yam 225 Shifting Problem swist Yamaha & Suzuki Outboards 19 August 6th, 2005 04:37 PM
HONDA 225 HARD SHIFTING OUT OF GEAR Fitch Honda & Tohatsu/Nissan Outboards 0 January 31st, 2005 06:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
