Re: 1973 Evinrude 65hp power loss
Get yourself an inline spark tester (couple bucks at autozone), set the gap at 7/16", clip it to the engine block, attach the spark plug leads (one at a time), and look for a sharp blue spark while somebody turns the engine over with the key. All plugs should be out, and the other two leads need to be grounded to the block for this test.
Bad spark on one or two, swap it with a good coil & retest -- problem follows the coil, replace it. Problem stays with the cylinder, you'll have to troubleshoot the timer base.
Or, the manual gives resistance specs for testing the coils with an ohmmeter.
From your description though, sounds like you are just about due for a carb rebuild. Choking a warm engine should flood and kill it.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
