Hey Guys, I am brand new to the forum. I was searching the net for the year of my little motor and found you guys. The motor in question is a 1954 Johnson 5.5, model CD-11, serial 176951. Anyways I was just about to take her in for service and I found this site. I know I am new but here's my problem. The motor usuallu starts second or third pull Idles really high, won't low idle and does not seem to be reving out on the top end. I have done nothing to this motor.
I should also note that the control handle does not lineup with the positions fixed on the handle? Do I just adjust the gear on the opp end? Although I am sure this isn't the first place to start the tune-up. SO my question is where do I start? I have also found this website
http://www.outboard-boat-motor-repair.com/Default.htm
which looks very detailed, so do I really need a manual? I am located in Southern Ontario Canada, Where would be my best bet for parts? That website that I posted up has Napa as a part source? Well thats alot of questions but the main question is where do I start?
Thanks in advance for any help
Grant
Grant
