We have a mercury 125 that cranks, starts when u spray gas in the carb, but gets no fuel on its own. We rebuilt the fuel pump today, and still....no fuel. There is fuel in the tank and the primer bulb does tighten up when pumped. We even took the gas cap off to try venting the tank to allow it to pump. What makes the diaphram move? please help us!!! We want to get the boat out at least once this season.
thanks
Reason: Felt like it
Could it be an anti siphon valve...cause i watched the gas in the line very slowly go back to the tank. i just dont understand why the pump pulls nothing.
Pumping the primer bulb should fill the carbs and allow it to start.
Pull a fuel line from the pump or a carb and squeeze the primer bulb, if NO FUEL then start checking lines/fitting to find the plugged one and replace it.
I've found quick disconnect fitting missing the little 'nipple' that unseats the ball valve and 'No flow'.
thanks for the ideas, however i still want to know what makes the diaphragm move. I dont see any vaccum lines or mechanical arms that move the diaphragm to start the movement of fuel.
So if that vaccum line is plugged, i obviously wont get pulse from the crankcase. Is that a common problem, or does that lean more towards compression?
