problem rough idle and stalling when i move trottle shafts at idle it ends up running smoother:
R reel Recruit Joined Jul 7, 2008 Messages 3 Jul 7, 2008 #1 problem rough idle and stalling when i move trottle shafts at idle it ends up running smoother:
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jul 7, 2008 #2 Re: 1996 50 2 cyl when were the carbs last clean? spark on both cylinders? what are your idle rpms? compression? last maintenance done to motor.
R reel Recruit Joined Jul 7, 2008 Messages 3 Jul 8, 2008 #3 Re: 1996 50 2 cyl tashasdaddy said: when were the carbs last clean? spark on both cylinders? what are your idle rpms? compression? last maintenance done to motor. Click to expand... just cleaned the carbs ,yes spark on both cyls,compression 140lbs on both cyl idle rpm is abou 1200rpm in drive in the water
R reel Recruit Joined Jul 7, 2008 Messages 3 Jul 8, 2008 #4 Re: 1996 50 2 cyl also noted that the throttle will not return to its stop
W wilde1j Vice Admiral Joined Apr 15, 2002 Messages 5,964 Jul 8, 2008 #5 Re: 1996 50 2 cyl Idle is way too high. Should be ~ 600 to 650 RPM in gear in the water.
