  #1
Old August 2nd, 2008, 09:12 AM
mrj702 mrj702 is offline
Angry yamaha 150 carb 2002 oil reserve refill
My yamaha 150 carb has an oil reserve inside the engine. when it gets to bottom line it is suppose to refill from the outside reserve. I had a mechanic look at it. he supposidly checked the wiring & replaced a short-still did not refill. he is now saying it must be the float. I can manually refill the reserve by using the toggle switch. does anyone agree it could be the float? If so, where is the float located (is it connected to the cap)? please excuse the questions in advance if they seem to simple as I am mechanically challenged.
  #2
Old August 2nd, 2008, 10:36 AM
rodbolt rodbolt is offline
Default Re: yamaha 150 carb 2002 oil reserve refill
what year 150?
they changed the operating system a few times over the years.
its very very simple, you did not have a short,trust me on that.
do you have a multi-meter? if not buy one and we can walk you through this simple technician killer.
  #3
Old August 2nd, 2008, 12:28 PM
it is a 2002
  #4
Old August 2nd, 2008, 12:32 PM
Also, I have a multi meter so please direct me from here
  #5
Old August 3rd, 2008, 11:56 AM
ok, first we have established the power to the transfer pump in the remote tank is ok as well as the ground path as the manual transfer works.
however, if the remote tank is low or the switch for it has an open circuit you will get a yellow lamp,or middle bar or arrow, on the tach and automatic transfer wont occur, first place to start is to check the remote tank level then the switch, if the tach shows green or three bars skip that step.
to test the float switch in the engine tnk first drain the tank by removing the vinyl trap, then remove the float switch and screen paying attention to the vent hole on the screens orientation to the tab and flat on the switch for reassmbly.
using your multimeter with the float ll the way up should be closed circuit between the blue/white and black, thats the command for pump off, between blue/green and black qwith the float at midpoint you should see closed circuit this is the pump on command, with the float all the way down between the blue/red and black you should see closed circuit,this is no oil and RPM reduction command.
black is the ground path for all three switches.
after 1995 all V6 engines have to be running for automatic transfer to occur, however there is trick. with the remote tank over 1/2 full and the engine tank below the second line it will initiate a 180 second transfer cycle and flash 3 bars at key on engine off.
its a quick way to test the alarm and the oil transfer rate, if it cannot refill the tank in 180 seconds then look for a clogged remote tank filter or a pinched hose.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gas mixed, by accident in my Yamaha 200 HPDI oil reserve oceanluvr30 Non-Repair Outboard Discussions 5 July 25th, 2006 03:51 PM
gas mixed, by accident in my Yamaha 200 HPDI oil reserve oceanluvr30 Yamaha & Suzuki Outboards 1 July 24th, 2006 10:00 AM
2000 opti 150 pulling oil from reserve tank instead of ctoolman Mercury & Mariner Outboards 11 September 14th, 2005 03:15 PM
Yamaha Low Reserve Oil newdmw Yamaha & Suzuki Outboards 4 August 21st, 2005 05:59 PM
'91 Yamaha Oil Pump/Reserve SctSimpson Yamaha & Suzuki Outboards 8 June 19th, 2005 08:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
