I had my boat out for the first time this year, FINALLY! And after running around at half throttle or so to run some fuel through it and get it warm, we stopped to do some still fishing and when I went to start it the "overheat" (?) alarm was going off. Have never had this happen before and wasnt exactly sure what it was. Water was coming coming out of the "spray holes" as normal, seemed like normal stream. Started normally and then the alarm was intermittent. it ran fine without alarm sounding, returned to dock and trailered home. Checked the alarm by grounding the lead and worked as normal. Checked gear case lube and found alot of water... put motor in vertical position and had lube and water coming out from around the prop shaft also, bad I would imagine?? Would this condition cause an alarm, and what is the prognosis for the gear case and the leak? I have never noticed it leaking while on the trailer, it is garage kept and never sign of a leak.
Also noticed slight fore and aft play in prop shaft, maybe 1/8". Thanks all!!!
