Re: Do I need to flush out engine
Care & feeding of boats: beginning of season
wash boat, wax every glass surface possible (except non-skid boarding/walking areas)
use 303 fabric protector on Bimini/vinyl seats.
spray Corrosion Block on underdash wiring terminals
Ok,so now your protected for the season,Maintainance:
after use - wash boat with BOAT soap (Orpine) as to not remove wax, dry all surfaces.If hull gets discolored use TSP - Tri Sodium Phosphate-dissolved in H2O to remove discoloration,try not to get suntan oil/lotion on vinyl,cloth seat protectors work great & cheap, Motor- rigidly follow manufacturers routine maintainance schedule,don't skimp on oil..use quicksilver,as opposed to a cheaper brand.If you trailer the boat every outing its easier to keep clean,if shes in the water ...i know its a pain...but get into a routine and stick by it.
Recommended products -wax,Collinite ( e-bay) 303 surface protectant - Good Luck Amigo!! & Have Fun
