  #1
Old July 31st, 2008, 09:37 PM
woodnknots woodnknots is offline
Default 1994 Yamaha 200hp wierd idle, surging
When I say wierd, I mean that it sounds sort of like a Harley Davidson motorcycle idling. Not very smooth at all.
I took it out on the water for the first time ever today to test it out (just bought it, installed it) and it seemed to run a little rough at low speed, then when I brought it up on power it came to life with all sorts of power, then right away started losing power, then surging, then losing power, then surging. I couldn't get full power back at all, so I immediately turned around and came back.
What I've done so far- Checked spark gap-good .040
Checked all plugs to make sure all had soot from firing (they do)
drained carb bowls (maybe a water problem?).
One more thing, the sticker on the inside of the motor calls for NGK BR8HS-10 but it has brand new B8HS-10 (no R). Does this matter?
Motor is Yamaha model 200TXRS serial 766580
__________________
"He is still behind us, I wonder if he is using the same wind we are using?"
  #2
Old August 1st, 2008, 08:47 AM
Default Re: 1994 Yamaha 200hp wierd idle, surging
I wanted to also ask about a possible symptom. I pulled off the airbox from the carbs, and there was gas pooling in the front part of all the carb barrels. Is this normal? Or am I getting too much fuel and flooding the plugs?
UPDATE: I replaced the spark plugs with the correct ones (resistive) and will probably try it on the water tonight. The idle doesn't sound much better as far as I can tell, but it's possible that these were symptoms of different issues. Won't know until I can get it on the water.
__________________
  #3
Old August 1st, 2008, 07:45 PM
I think I found the problem. The fuel pumps are rusty inside and one spring is broken and the other spring hardly has any spring left. I'm going to try and rebuild them and see where it goes from there!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 91 200Hp wont idle on/off Yamaha & Suzuki Outboards 2 June 13th, 2009 10:20 PM
1999 Yamaha 200hp OX66 surging erraticly john mc Yamaha & Suzuki Outboards 14 December 13th, 2007 09:45 PM
Yamaha Surging Power/Idle Problems cookiedoh Yamaha & Suzuki Outboards 6 July 4th, 2006 10:22 AM
1994 Yamaha SWS 250 Overheat at Idle dteufle Yamaha & Suzuki Outboards 3 May 24th, 2005 03:01 PM
1994 225HP Yamaha surging jbhemm Yamaha & Suzuki Outboards 5 July 16th, 2004 12:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
