  #1
Old July 31st, 2008, 03:41 PM
Walliwally Walliwally is offline
Default 1998 115 OB Mercury slips out of gear
I can idle forward and reverse fine, but when I punch it down it starts to take off, then the engine over-revs and the prop quits turning as if it is slipping out of gear.
I checked linkage etc., and all seems fine.
Tightened Prop and checked hub...seems fine.
I didnt try real hard in reverse, but doesnt seem to do it.
Not sure if its related or not, but also dont have any water coming out of the "pisser".
And another wierd and seemingly unrelated thing, I show 18+volts on the meter (never has before)..almost pinned.
Any help at all would be much appreciated.
  #2
Old July 31st, 2008, 09:46 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: 1998 115 OB Mercury slips out of gear
It sounds like you may have spun the splines out of the bottom of the crankshaft. This is bad... Do you have water coming out of the telltale when the engine is running at idle, and only loss it when it 'pops out of gear'?
Chris......
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old August 1st, 2008, 08:38 AM
CharlieB CharlieB is offline
When it acts like it is slipping and you pull the throttle back to idle, but still in forward gear, is the prop still turning and slowly pushing the boat?
Make the hub and shaft, put it in forward gear, engine OFF, on the trailer, STAND on the prop, can you make it slip?
If it is not a slipping prop, if it is clunking in and out of gear, then it may be time to replace your stretched shift cable.
  #4
Old August 1st, 2008, 04:25 PM
PJSuburby PJSuburby is offline
I have the same engine, but have not had that problem.
Pull the cowl off and check that the shift cable pulls the shift linkage ALL the way when you shift forward. The cable may not be moving linkage enough to fully engage. Easy to check and easy to adjust. Good luck.
I just replaced shift and throttle cables. Easy to do also.
  #5
Old August 1st, 2008, 09:35 PM
achris's Avatar
Hey, y'all,
He's got no water from the telltale! How does an incorrectly adjusted shift cable cause that?????? Crankshaft splines!!!!!!!
Chris.........
__________________
  #6
Old August 4th, 2008, 10:07 AM
Thanks everybody...I appreciate all the help.
Update. I drove it about 4hrs (long story, but short version is I had to for a 80th b-day party).
Checked cables, all ok.
If I accelerate extremely slowly, I can feather it up to about 30mph, but it takes the whole lake.
Up to between 2500 and 3000 rpm it stays in gear, but if I try to get there too quick, it "slips" and I have to start all over again.
I do not have to pull it all the way out of gear. Once it tachs down to about 1000 rpm, it "catches" again.
Any requirement for extra power (more people in the boat, etc.) and it slips sooner.
It shifts into forward and reverse solidly and it appears like I could idle around the lake all day if I want.
Spline theory seems to be the most plausible..thanks achris!!
Also, I still have no water coming out the telltale, but it didnt overheat, and my voltmeter still reads over 18 volts most of the time, yet the battery didnt blow up.
Again, many thanks to everyone.
  #7
Old August 5th, 2008, 07:20 PM
Well, You have to follow up with this thread and let us know what it was.
Hope you rule out ALL the simple things before attacking the engine guts. Seems to be the wisest move.
Good Luck!
  #8
Old August 8th, 2008, 08:38 AM
Two seperate problems
1 Slipping prop hub, holds at low power/throttle, slips once power is increased, try another prop, then send this one in to replace the hub.
2 Tell-tale plugged, run a small wire up into it to clear or blow into it with an air hose.
  #9
Old August 8th, 2008, 01:19 PM
Already a brand new hub and prop
  #10
Old August 8th, 2008, 09:34 PM
What STYLE hub, too many times the partsman sold the WRONG hub kit with a good prop.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Does my 1998 115 have a plastic oil pump gear ? MercGuy Mercury & Mariner Outboards 0 September 28th, 2007 02:04 PM
1979 Seahorse 115 slips out of gear redmopar Johnson & Evinrude Outboards 4 December 1st, 2004 08:02 AM
motor slips out of gear while in Fwd gear Glassmaster Non-Repair Outboard Discussions 1 July 31st, 2004 03:07 PM
Slips out of gear? pvisser Johnson & Evinrude Outboards 2 July 22nd, 2003 12:28 PM
Slips out of gear? pvisser Non-Repair Outboard Discussions 1 July 20th, 2003 07:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
